5 Replies Latest reply on May 10, 2013 8:40 AM by Don Van Zile
    Set Entity Name - Assemblies
    Mohammad Shaheer Zubairi
      Hi all,
      I'm using the code below for part models to assign a name to every face in the model. Essentially, I m right-cliking on a face in SWs and selecting Face Properties and giving it a Name in Entity Information box - all via API.
      Option Explicit
      Dim retval As Variant
      Dim i As Integer
      Dim swFace As SldWorks.Face2
      Dim matProps(8) As Double
      Dim currface As Integer
      Dim boolstatus As Boolean
      Dim obj As Object
          If Not swApp Is Nothing Then
                  Set swModel = swApp.ActiveDoc
              If Not swModel Is Nothing Then
                  Set swPart = swModel
                  If Not swPart Is Nothing Then
                      retval = swPart.GetBodies2(SwConst.swSolidBody, True)
                      For i = 0 To UBound(retval)
                          Set swFace = retval(i).GetFirstFace
                          currface = 1
                          Do While Not swFace Is Nothing
                              swFace.Select False
                              Set obj = swModel.SelectionManager.GetSelectedObject5(1)
                              boolstatus = swPart.SetEntityName(swFace, "Side # " & currface)
                              Debug.Print swPart.GetEntityName(swFace)
                              Set swFace = swFace.GetNextFace
                              currface = currface + 1
                      Next i
          Set swApp = Nothing
      I'd like to do the same to the faces of components in an assembly. I've traversed the assembly and tried to do it that way, but to no avail. I can select the faces in different components in an assembly via the API, but I can't assign the entity name to the faces in the components in the assembly model like I can for the parts models.
      I can't think of a way to correctly do the operation in the assembly. The code always breaks at:  boolstatus = swPart.SetEntityName(swFace, "Side # " & currface) as I'm working in an assembly.
      Any help or advise will be much appreciated.
