I have a part that was given to me with the part being not in line-of-draw. The part is all contoured (no flat planar surfaces). I was able to create reference planes on the part to get a plane eventually that represented line-of-draw. How can I align the part to the main plane using this reference plane? I know I can create the tooling split without doing this step, but, to make things easier down the road, I prefer to have the part aligned to the main part coordinate system.
Create an "L" shaped sketch on the reference plane you created...with the two lines pointing in the directions that you will want the "X" and "Y" origin axis to be...and exit the sketch. Then create a Coordinate System using the intersection of the two lines as the "Origin" and the two lines being used to define the "X" and "Y" direction. Save as, Save as type = Parasolid (*.X_T), Options, Output coordinate system...select the one you just created from the pull-down, OK, Save.
Open the parasolid file. If you did it right, it will come in oriented how you want it to be.
