ASAndreas Senai03/05/2013
Hi there,
My company has standardized around the comma as the "system separator" for decimal values.  This option is easily selected in the General section of the System Options.  The commas show up fine everywhere except for hole callouts.  For example, if I have a clearance hole for an M4 screw, the hole callout version of the dimension will show 4.5.  We usually get around this simply by using Smart Dimension to callout the hole, but when it's anything other than a thru hole, this gets annoying (having to put in depths manually, etc.)  Another place the decimal point shows up in place of a comma is for thread callouts (i.e. M6x1.0).
I've fiddled around with the hole callout format file in the past but cannot find a way to fix the decimal point issue within that text file.. is there anyone who could help me with this? Maybe there's another way to override decimal points coming from the hole callout format file?
We're running SW2012, SP3.0
Any help is much appreciated.
Andreas
