JHJames Han03/05/2013
Hello all,
The error first occurred when I was editing the drawing file.
An error about that particular file’s auto-recovery file was showing up every time I tried to save or tried to edit the properties of an object.
Along with the auto-recovery file error, Another error followed it stating: "An unknown error occurred while accessing [File Path].SLDDRW."
I closed the file and tried to reopen it and every time I tried to re-open it, it would give me the same errors. I tried opening the actual model of the assembly and the model opened up just fine.
Due to this problem and my inability to save or re-open the drawing file, I started over from scratch (this way I can be sure that the problem does not arise from something that already existed in the drawing file).
After getting through most of the design for the drawing file, I ran into this issue again and again.
It works fine for a while when I create a new file and start building up the drawing file. Then, at some point near the end, it starts getting these errors.
The errors I am getting now are mostly just the "An unknown error occurred while accessing [File Path].SLDDRW" error alone, and the auto-recovery error does not show up as often (only after certain actions).
I could not pinpoint a cause to this problem as of yet.
So far, I created the same file from scratch 3 times over, and ran into the problem every time.
At this point in time, I am suspecting some error in the assembly that may be trickling down into the drawing file after I mess with some of the features within the drawing file. But things were fine in SW2012, why am I having this issue with SW2013?
I need help in diagnosing this issue please, as I do not want to keep having to throw out my work.
