I'm trying to add some handle features and I've run out of solutions to this constant error. Any help would be really appreciated!
Basically, I'm using the Boundary Surface feature with three main surfaces defining the path direction and several sketches defining the shape. I've done this many times in the past, but an error noting that I cannot have mixed open and closed loops keeps popping up. As you can see the Property Manager won't select the entire border of the surface as the Open Loop. I've gone back to the sketches and everything is a closed loop.
I've also tried just creating surface offsets at 0mm, just to create single surfaces for each of the three shown in green below then selecting those three surface offsets as paths and it won't allow me to do this either.
I've attached the model as a reference.
Travis
