When I click on the "Preview Window", the window pops up, however the actual content within the window never appears, it freezes an image of whatever was behind the window (my desktop in most cases), and it will never actually load the Preview, even after several minutes. If you drag the window around, it just moves that same frozen slice of whatever was displayed behind the window at the time of opening.
A coworker's older computer running the same version of SolidWorks will load the Preview Window just fine.
Any advice would be greatly appreciated. A forum search and Google search came up with no similar cases. Thanks!
My Build:
GIGABYTE GA-Z68A-D3H-B3 LGA 1155 Intel Z68 ATX Intel Motherboard
Intel Core i7-2600K Sandy Bridge 3.4GHz (3.8GHz Turbo Boost) LGA 1155 95W Quad-Core Desktop Processor Intel HD Graphics 3000 BX80623I72600K
Intel 320 Series SSDSA2CW080G310 2.5" 80GB SATA II MLC Internal Solid State Drive (SSD) - OEM
Western Digital Caviar Green WD7500AARX 750GB IntelliPower 64MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
CORSAIR XMS 16GB (4 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model CMX8GX3M2A1600C9
ATI 100-505606 FirePro V4800 1GB GDDR5 PCI Express 2.0 x16 Workstation Video Card
CORSAIR Enthusiast Series TX650 V2 650W ATX12V v2.31/ EPS12V v2.92 80 PLUS BRONZE Certified Active PFC High Performance Power Supply
Windows 7 Professional 64bit
I've seen this occassionally. First thing I do is reboot. If that doesn't solve the issue I put my model into an assembly file and see if the new assembly file will load into preview.
Not sure how large your assembly is but very large assemblies can take a long time to load into preview. I have some that will take 30-40 minutes to load, they are 40-50K component assemblies.
