Hey there,
i am trying to mate the following parts.
i want the wheel to stay tangent to all the inside faces of the bent plate. Already tried this with a cam mate, and path mate but it doesn't produce the right solution.
Is there a way to do this?
thanks in advance.
with kind regards JD
I was able to get it to work with a pathmate. You just need to put your path in the center of the wheel, rather than using the outer edge.
Here's what I did:
Create a sketch on the front plane of Part4. Use "Offset Entities" and select each of the bottom edges and offset 150mm (radius of follower.) When you create the Path Mate, use the center point of your wheel as the Component Vertex, and use the SelectionManager on the path to select the entire Open Loop.
You might want to consider adding radius' to smooth out the profile as well.
