Hi All,
Is there a way to set a data card field for multiple files? For example: I want to change the vendor field for 10 files to "MSC." The only way I know to do that right now is with dispatch. Maybe have dispatch ask me about the Vendor, then it will take that value and apply it to all the selected files. The problem is that if I triger the dispatch with a transition, and I only selected one file, but that file has 9 references, the dispatch will only write to the one selected file, not the additional 9 files that were referenced and went through the transition.
Any ideas???
Stephan
Hi Stephan,
You can accomplish this either through dispatch or a transition action. There are others but these are low hanging fruit.
Tim CEPA
http://www.equivaq.com
