4 Replies Latest reply on Apr 25, 2013 5:35 AM by Steven Smith
    TextBox that groups ComboBox data.
    Steven Smith
      Hi Guys, & Girls.
      I have a basic userform that allows the textbox to combine and display the values in the first 2 ComboBox's together.
      I'm looking for some help, when populating the 3rd and 4th ComboBox's, I would like it to override the data in the texbox.
      I'm thinking along the lines on If xxxx = False Then xxxx but im too inexperienced to string it all together.
        • Re: TextBox that groups ComboBox data.
          Steven Smith
          It helps if i load the correct macro. sorry.
              Gabriel Lorenzo Yangzon
              I cant open your macro I annalyzed your question
              just a try
              I used C#
              if ((comboBox3.Items !=null) ||  (comboBox4.Items != null))
                              textBox1.Clear();
                              foreach (string val in comboBox3.Items)
                                  textBox1.Text += val;
                              foreach (string val in comboBox4.Items)
              combobox3 value = abcd
              combobox4 value = efgh
              edit: I opened your macro I fixed it tell me if its wrong thanks
              Regards,
              Gabriel
                Artem Taturevych
                Excuse me I do not completely understand what you are looking for. Do you want to fill the text box when you select some values in comboboxes? If so you need to handle the ComboBox3_Change/ ComboBox4_Change events and set the value for the textbox via ::Text property.
                ____________________________________________________
                Regards,
                Artem Taturevych, Application Engineer at Intercad (Australia)
                LinkedIn SolidWorks API Education Group
                Steven Smith
                Hi Gabriel, the updated macro you attached is what i was looking for, thank you. There is alot more as to what I require, but this will give me a starter for what I need.
                I generally, just need a push in the correct direction.
                Hi Artem, Thats exactly what im looking to achieve, what you have suggested.
                The selected values in the 1st set of combobox's will populate the textbox, and when I look to populate the second set of combobox's they would overwrite the values in the textbox with the new data.
                Basically, when we look to do a revision change we would like to select the revision number and a document level letter.
                the text box is used to show the current combination and will be pulled into the drawing sheet.
                Hope this makes more sense.
                Cheers.
