I have a spline on surface (see image) and I need to set tangency to surface edge (to trim the corner).
I drag and connect the endpoint to the surface edge OK
Ctrl select the curve and the surface edge > select the tangency relation
Keep getting an 'over defined' error
Any suggestions?
(I've attached the file but it's from an educational license)
Have you consider using an actual fillet?
See attached.
