Currently, when creating weldment cut-lists, the default material value is linked to the assigned material ("MATERIAL@@@<cut-list name>@<filename>". I'd like to change the default so that it is not linked to the integrated material feature in SolidWorks (i.e. just use a text string as the default). Is there a way to change this?
Sally, open the weldment profile in it's own window (you can do that by right-clicking on the profile in the task pane) and add a custom property for material along with the text string that you want to include.
Alternatively, I believe you can edit the material string in the cutlist.
