i desgined a conveyor belt but it seems that the belt does not move. i but a box to check if the belt moves or not it came out that just the two shafts are moving without the belt. what shall i do?
The belt will not move but the two shaft will. This is how the program has been defined. In case you want the be;t to move, then you need to make chain of small-small blocks connetced together and make them move using mates.
Similar to the chain animation. Check this animation and SolidWorks files by Gerald Davis if this helps
Difficult animation (Chain Animation)
Re: Difficult animation (SolidWorks files used for above animation)
