4 Replies Latest reply on Apr 22, 2013 9:53 AM by David Spencer
    Equations
    David Spencer
      Is it possible to creat a n equation that will automaticly round the size up?
      Example: D14@SideSk = D12@TopSk to the next Nominal number. Rounded
      So if D14=34.485 it would round the part up to 34.500" or even 35.000"
      I know i can override the Dim in the drawing or set the Primary precision to none or .1 but that still leaves the part at 34.485
        • Re: Equations
          John Burrill
          David, you can use an IF statement with the INT operator to round numbers.
          For example  where D`1 is an equation-driven dimension and D2 is an input value
          =if("D2@Sketch10"-int("D2@Sketch10")>0.5,int("D2@Sketch10")+1,int("D2@Sketch10"))
          -will round the dimension to the nearest whole number
          If you want to introduce significant digits, just multiply the input value by 10^x power where x is the number of significant digits.
          Sof for example, if in the above case I wanted to round the result to two significant digits, I'd enter the value as
          =if(100*"D2@Sketch10"-int(100*"D2@Sketch10")>0.5,int((100*"D2@Sketch10")+1)/100,int(100*"D2@Sketch10")/100)
          For the purposes of making the equation easier to edit, I probably would split out the pieces into a couple of seperate equations
          For example
          Global variable: Sig_digits; Value: 2
          global variable:primer; equation: =10 ^ sig_digits
          and then rewrite the equation so that all I have to change is the sig_digits value to adjust the precision of the equations.
          Try it out.
          John
          • Re: Equations
            Jason Capriotti
            In addition to John's suggestion, you can use a "Round" operation.
            round ("a")
            a = 34.485
            b = round ("a")     ' =  34 (Rounds to the nearest whole number)
            c = round ("a",2)  ' =  34.48 (Rounds to two decimeal places)
            d = iif ( round ( "A" ) < "A" , round ( "A" ) + 1 , round ( "A" ) ) 'This would always round up to the nearest whole number.
            • Re: Equations
              David Spencer
              Thanks for the help guys. Works like a charm.
