I have an assembly that I revieved, and it contains many parts, and the features inside each part are all supressed. Presumably, they did this to reduce file size.
Is there a way to supress all of the at once?
Using SW2011
Using SW2011
David,
if you have the selection filter toolbar active, click the Select icon and click select suppressed. This will select all suppressed parts/sub-assemblies, you can then RMB on any of the selected and unsuppress.
This should work in the parts also.
I'm thinking you'd need some sort of macro to unsuppress at assembly and part levels in one move.
