I have a number of seemingly empty folders in a SolidWorks EPDM 2012 SP3 vault that are tagged as deleted, but when I attempt to destroy them, I get an error stating:
"Could not access the item in the database"
I have tried restoring an earlier version and checking out/in and hoped that the vault cleaner service would help, but just cannot get rid of the folders. Also tried modifying the user profile to only show files that are part of the vault and checked the local file clean-up to delete local read-only files that are not part of the vault.
Entry from the EPDM Administration log file as follows:
Description:
Error running query in SpDbOdbc
State=23000
Msg=[Microsoft][ODBC SQL Server Driver][SQL Server]The DELETE statement conflicted with the REFERENCE constraint "FK_ControlledLists_CardControls". The conflict occurred in database "bob2013", table "dbo.ControlledLists", column 'DestCtrlId'.
========= LAST COMMAND ========
Del_ApiDestroy 2
Server: samwise\epdm
Database: bob2013
Date: 2013-04-18 16:23:28
Module: Explorer.EXE
Function: hGetErrCode
Error code: E_EDM_DATABASE_ACCESS
Error code general description:
Could not access the item in the database.
Any help would be greatly appreciated.
Wayne,
It looks like when you delete the folder there is a datacard associted with that folder that is getting deleted as well. In that data card there is a list that is controlled by a variable like so:
You can probably go in and try to delete these references first then you should be able to destroy the folders. You should pass this information on to your VAR to put in a service request to get this issue resolved.
