Hey everyone, first post here! I'm not entirely new to solidworks, but I never had any formal training till I took the Fisher/uni basics class a while back.
Anyway, I'm having a small problem. I'm trying to place three holes on the outside surface of a hollow cyllinder. These holes are offset 120 degrees from each other, equally spaced. I made refrence plane to make a refrence sketch for the hole locations. When I go into hole wizard and try and place my points for hole centers the preview looks perfect, but once I actually place the point the hole goes rouge and takes off in the wrong direction.
This picture explains it better than I can. The prieview with the hole going towards the center of the part is right, and that's what shows when I hover a point over the proper location. As soon as I place the point, the hole goes the wrong direction.
]http://imageshack.us/scaled/landing/401/hole1.jpg
If I don't place the points on the refrence sketch I made to locate the holes they work as they should. It's only when I try and put them where they actually need to be that things go wrong. That sketch is somewhat hard to see in this picture. It's basically just construction lines coming from the center of the bore, coinsident with the round outer surface. Dimensioned to be 120 degrees apart.
Any ideas?
Thanks for looking!
Make sure you add an On Surface relation between the points and the outer surface. Without it, SW has no reference of which direction you want the hole to go.
The easiest way to do this is to place your hole wizard points on the surface first, then add relations to the control sketch.
