I have two plastic parts and they are actually designed to fit together in an assembly, but now they want to get it quoted as one part. So what i have been doing is bringing in one of the two parts into a new part, then bringing in the other part using>Insert>part and selecting my part. Finally where i am getting stuck is trying to COMBINE the two parts and merge as one...
I would have just simply re-modeled it to make everything cleaner, but it is a very intricate part with multiple contoure and other such features. I even tried to extrude between the two but keep getting the invalid geometry/zero thickness message..
Any suggestions??!
Try adding a small amount of extra material to the upper body so that the two have interferance. This should help with the zero thickness error.
If that doesn't work, can you post the file?
