When I save a sheet metal component to Dwg file for plasma cutting, the default output adds "Flat Pattern" before the name of component.
Is it possible to change the default to something else?
I know I can edit the name as I save, just curious if the default can be manipulated.
Carl, are you saving it directly from the sheet-metal part or from a drawing sheet?
