Running SW2011 SP5.0
I have an assembly, with 80 parts.
I want to delete one part.
But maybe other parts' geometry are tied to the part I want to delete.
So first I want to see which other parts, if any, are referencing the part I'm going to delete.
So I know which parts I will need to repair if I delete that part from the assembly.
Help section says Find References - "Lists files referenced by the active part."
I want to do the opposite - see which files are referencing the active part.
So the part I want to delete is referenced by.... which parts?
If you are talking about external references, then there is no way of tracking them. A SolidWorks file does not keep track of what is using it as a reference.
