I'm modeling a connecting rod and made a mistake which is I used MM instead of using Inches carrying the same dimensional value, for instance: 24.875 MM although it should be 24.875 Inches. The problem is that the part I'm talking about is the main part of the connecting rod which took too much time to be modeled, so it would be really hard to re-model again. Please help me with this, there should be a solution for such problem. By the way, I've heard about "Model rescaler" but I don't know how to use it, if someone could help with this, it would be great or just tell me a better idea if you got one already. I've attached the part by the way to let you see the part and if you can do it for me, I would appreciate.
Omar
Just run the ModelRescaler macro and use the Scale Up option with a Scale Factor of 25.4
NOTE: This macro only works on sketch dimensions, so if you haven't fully dimensioned your sketches, expect problems.
