Configuration Descriptions
Discussion created by Guest on Nov 10, 2006
Three ways:
1) In a design table, make a column with the variable name DESCRIPTION. For each configuration, type the description there.
2) In the Configuration Tree Manager, right click the configuration, select properties, type the Description in the Description box.
3) In the File Properties window, select the Configuration Specific tab, scroll to a configuration, add a property called Description, and type the Description there.
Getting the part number correct is even more fun. Best you learn how to handle a design table, as it is easiest once you have it down.
Dwight Livingston
SW2006 SP3.1 / Adept 6.0 / XP Pro SP2
2 gB ram / Quadro FX1100
