When will EPDM support AutoCAD 2014?
AutoCAD is one of few application that actually does not need support. As John said, 2014\2015 uses same file type that was used by 2013. Which as Jeff said is supported in EPDM 2013 SP3, However, by setting your file save type to 2010 or lower means the file is compatible with EPDM.
In saying that EDPM addon will not work for AutoCAD 2013+ till they offically release an update as the addon (ARX) is version specific of AutoCAD, had they used Dot net instead of C++ this would not be that case. However the EPDM addon for AutoCAD is useless any way so it is barly better than nothing.
