6 Replies Latest reply on Apr 15, 2013 7:27 AM by D. L
    Problem withISwDMDocument15.ReplaceReference()
    D. L
      hey guys,
      i have some problem with the replace function of the document manager api.
      i tried the following:
      var r = refObject.ExternalReferences;
      if (r != null)
           foreach (var s in new List<string>(r))
                var find = document.Children.Find(x => x.Source.ToLower() == s.ToLower() || x.Destination.ToLower() == s.ToLower());
                 if (find == null)
                _document.ReplaceReference(s, find.Destination);
      _document =  ISwDMDocument15
      I search fpr External References and the i look up in my object (document.Children) if i have a new path of the reference.
      If i have some new one then i tried to replace the reference.
      old:     C:\Work\test.sldasm
      new    C:\Check\test_123.sldasm
      The new on is the same file like the old on but has a new filename. The Problem is that the function works correctly under windows 7 x64 but when i try it under windows xp x86 then i get
      a com exception
      if i run the _document.replacereference function.
      have some on an idea for the problem?
      with greetings
