Hi all,
I am using Solidworks 2011, i am converting solidworks assembly file to parasolid format. The conversion has completed successfully,but the problem is parasolid file size is 2 times greaterr than the SW original file size.
Kindly give some suggestion!
Regards,
Vinoth
Vinoth,
Your SW assembly file contains different part files.
Don't look at the size of just assembly file
When you export into different formats, it converts main assembly and all part files within that assembly.
You are getting the add up size of all these
