i am doing a heap of library parts at the moment and i have notice SW (quite annoyingly) takes the evaluated value instead of the value/text expression of custom properties when opening the design table. is there a way to change this?
the work around i am using is to do all the values on Sheet 2 in the spread sheet and link the cells to Sheet 1 but this is only good if you remember to switch back to sheet 1 and update the cells being referenced before closing.
is there a better way of ding this?
Anyone? or is there a reason it does this that isn't obvious?
