2 Replies Latest reply on Apr 4, 2013 5:30 AM by Joy Garon
    Creating template - EPDM variables to Solidworks drawing template
    Simon Schuck
      Hi
      Im trying to work out from within Solidworks how you create a drawing template which automatically maps the variables from the part. The part has all the relevant information in it when created but its not pulling the relevant variable information across when you make a drawing from a part and select the relevant template. Can someone tell me where this info is setup within the drawing template please to which it then pulls from the model\part? I can manually insert the variable if I edit the sheet but it should pull across automatically.
