I have an assembly with several parts. I would like to have Part A change configurations based on a dimension from Part B in the same assembly.
Is there a way to set an equation or some other linking tool to drive the configuration of Part A from a dimension from Part B? I would like to keep Part A the same and not make any changes so I can do this.
Thanks for all of the help!
Kaare,
Yes, you can use Linked Dimensions or an equation to drive dimensions in one part by dimensions in another, provided they are both in an assembly. I seem to recall that you can only Link driving dimensions, so you can't drive a dimension by linking it to a driven dimension.
Jerry S.
