Hi everyone, I am trying to get ride off the extramaterial in my model,
Can anyone kindly share a method?
please see picture to see what I mean, using SW PRO 2012 X 64 SP4.0
Thanks and best regards
Did you try a surface cut using the rounded surface or even a straigth sketched cut.
Hi Tony,
Thanks for replying, Can you explain step by step if you don't mind?
I haven't used surfaces.
Try Delete face and then patch the area using surface tools.
Hi Deepak,
I tried but it pop ups a message that is says
"the faces cannot be patched due to geometry"
Looking at the part file, there should be a transition between the two surfaces meeting perpenticular.
The two surfaces are not in the same level.
You have to decide, how to match between these two faces
Jhon,
you are right, there are two levels
See attached part. It's not pretty, but an option none the less depending on your design intent.
Brian
Sorry, I didn't realize which version you were using. Here is a pic of one option.
Brian,
I appreciate the time you spent on this, I will play with your suggestion to see if I can get a better option than my second option.
Thanks again!
