I have created a Convert Task to PDF in EPDM. Everything works great except the Convert is actually doing a Save As PDF which takes our "custom" line fonts and turns them into solid lines. I would use a Print Task for the PDF conversion but this will not let us specify where the PDF is saved, what the PDF filename is, and the size of the PDF. Is anybody using custom line fonts in SolidWorks and found a workaround for this? SolidWorks has an SPR to fix this custom line font convert to PDF issue.
Thanks, Todd
Hi Todd
I am not sure that I understood your problem, but if you are reffering to SPR 648021:
"Convert to PDF task incorrectly displays font sizes with any mixed font note(s) and font spacing when SolidWorks Standard is used to run the task."
Then it is supposed to be fixed in 2013 SP3 which will be out soon..
Keren
