Okay, I'm still pretty new to Simulation so this might be a regular occurence but I've never encountered it.
I have a model of surface elements that I ran. I had to change one of the surfaces as the defining part was updated. Now the features that reference that feature have little green X's next to them. I updated the model as well as "update all components". I had to update one of the Fixtures and Pressures because their original surface was changed. They are properly defined again so it's not an error. And I remeshed and that didn't eliminate them.
They are on Fixture-2 and Pressure-3 in the image below which I highlighted. (I ran the simulation and the X's remain)
What do the green X's indicate?
so they are surface bodies? or sheetmetal shells? or parts you defined manually as shells?
does it run?
