I'm using three tasks for converting SW drawings to DXF, PDF & eDrw's, which automatically launch during an "Approve" transition, which works perfectly. What I would like to do, is to save these viewing files to a new folder, based on the assigned ECO number (which is a variable (t_number) automatically assigned to the ECO document via the serial number generator. Assuming I'll be using the Advanced Scripting Options of the Convert Task, how can I get that ECO number variable (t_number) into the Primary Output Path?
Joe -
Please reference the knowledge base solution how to read a variable value from the data card of the source file and use in the output filename.
Solution S-061104
Regards,
Joy
