2 Replies Latest reply on Apr 2, 2013 9:58 PM by Yong Ning
    Traverse Assembly at Component→Merge duplicate Component
    Yong Ning
      Sub Main1()
          Dim swApp                       As SldWorks.SldWorks
          Dim swModel                     As SldWorks.ModelDoc2
          Dim swAssy                      As SldWorks.AssemblyDoc
          Dim swConf                      As SldWorks.Configuration
          Dim swRootComp                  As SldWorks.Component2
          Dim bRet                        As Boolean
          Dim ii, nn
          Set swModel = swApp.ActiveDoc
          Set swConf = swModel.GetActiveConfiguration
          Set swRootComp = swConf.GetRootComponent
          Dim vChildComp
          Dim SwArr()
          vChildComp = swRootComp.GetChildren
          nn = UBound(vChildComp)
          ReDim SwArr(nn)
          For ii = 0 To nn
              Set SwArr(ii) = vChildComp(ii).GetModelDoc
              Debug.Print "Set SwArr(" & ii & ") → Object →" & SwArr(ii).GetTitle
          Next ii
      Run code result is
      Set SwArr(0) → Object →Rib.SLDPRT
      Set SwArr(1) → Object →Rib.SLDPRT
      Set SwArr(2) → Object →Web.sldprt
      Set SwArr(3) → Object →Pad.sldprt
      Set SwArr(4) → Object →BasePlate-S.SLDPRT
      My demand is Merge duplicate Component
      Tow Compoent (Rib.SldPrt) --- one Component(Rib.SldPrt)
      Set SwArr(1) → Object →Web.sldprt
      Set SwArr(2) → Object →Pad.sldprt
      Set SwArr(3) → Object →BasePlate-S.SLDPRT
          • Re: Traverse Assembly at Component→Merge duplicate Component
            Yong Ning
            Thank you tip
            Sorry, I'm Chinese with English, not fully express meaning.
                      d.Add filename, counter
            FileName → String
            I need FileName → String →  Object () →Set SwArr(ii) = vChildComp(ii).GetModelDoc
            Option Explicit
            Sub Main1()
                Dim swComp                  As SldWorks.Component2
                Dim compCount As Integer
                Dim vComponents As Variant
                Dim SwArr() As String
                Dim d As Object
                Set d = CreateObject("Scripting.Dictionary")
                Dim i As Integer
                Dim key As Variant
                'd.CompareMode = TextCompare
                Dim counter As Integer
                Dim filename As String
                Set swAssy = swModel
                compCount = swAssy.GetComponentCount(False)
                vComponents = swAssy.GetComponents(False)
                counter = 0
                For i = 0 To compCount - 1
                    Set swComp = vComponents(i)
                    filename = GetFileName(swComp.GetPathName)
                    If Not d.Exists(filename) Then
                        counter = counter + 1
                    Else
                Next i
                ReDim SwArr(d.Count - 1)
                For Each key In d.Keys
                    SwArr(d(key)) = key
                Next
            Private Function GetFileName(FilePath As String) As String
               Dim l() As String
               l = Split(FilePath, "\")
               GetFileName = l(UBound(l))
            End Function
