17 Replies Latest reply on Nov 16, 2015 2:54 PM by Carlos Guevara
    How to get X&Y coordinates of all points
    Danijel Radenkovic
      Hello there. I have a problem to make macro for getting X&Y coordinates of all points from sketch (see a picture), but on new coordinate system. Can anyone help me?test.png
      Thanks in advance
      Danijel
        • Re: How to get X&Y coordinates of all points
          Manish Kumar
          Hi Danijel
          You can try something like tihs
          Dim oPart As ModelDoc2
          Set oPart = swApp.ActiveDoc
          Dim oSketch As Sketch
          Set oSketch = oPart.SketchManager.ActiveSketch 'Get Active skecth
          Dim sketchPointArray As Variant
          ' Each item of this array will give you a sketch point in the active skech
          sketchPointArray = oSketch.GetSketchPoints2
          Dim i As Integer
          For i = LBound(sketchPointArray) To UBound(sketchPointArray)
              'MsgBox sketchPointArray(i).X & " " & sketchPointArray(i).Y & " " & sketchPointArray(i).Z
          Next
          Regards,
          Manish
            Jerry Steiger
            Danijel,
            You might want to ask this in the API forum. The people who can answer you best will be more likely to see it there.
            Jerry S.
              Danijel Radenkovic
              Hello my friends, I tried to ask this question on API section of the forum but I don't have a permission, maybe because I am new member on this forum.
                Danijel Radenkovic
                I found an macro which doing what I want, but Default coordinate system named (origin). How to modify macro to works on diferent coordinate system (in my case "Coordinate System1")?
                ' Option Explicit
                Public Enum swSketchSegments_e
                    swSketchLine = 0
                    swSketchArc = 1
                    swSketchEllipse = 2
                    swSketchSpline = 3
                    swSketchTEXT = 4
                    swSketchParabola = 5
                End Enum
                    Dim swApp                           As SldWorks.SldWorks
                    Dim swModel                         As SldWorks.ModelDoc2
                    Dim swSelMgr                        As SldWorks.SelectionMgr
                    Dim swFeat                          As SldWorks.feature
                    Dim swSketch                        As SldWorks.sketch
                    Dim i                               As Long
                    Dim bRet                            As Boolean
                    Dim vSketchSeg                      As Variant
                    Dim swSketchSeg                     As SldWorks.SketchPoint
                    Dim nLength                         As Double
                    Dim xValue() As Double
                    Dim yValue() As Double
                    Dim zValue() As Double
                    Dim point_count As Integer
                On Error GoTo error:
                     Set swModel = swApp.ActiveDoc
                    If swModel.GetSaveFlag Then
                            MsgBox "Part/Assembly must be saved", vbCritical
                            Exit Sub
                If swModel Is Nothing Then Exit Sub
                    Set swFeat = swSelMgr.GetSelectedObject5(1)
                If swFeat Is Nothing Then
                    Set swSketch = swModel.GetActiveSketch2
                    If swSketch Is Nothing Then
                        MsgBox ("you must select the sketch from feature manager tree or at least be in a sketch")
                        Exit Sub
                Else
                    Set swSketch = swFeat.GetSpecificFeature2
                        vSketchSeg = swSketch.GetSketchPoints
                        point_count = UBound(vSketchSeg)
                ReDim xValue(point_count)
                ReDim yValue(point_count)
                ReDim zValue(point_count)
                    For i = 0 To point_count
                        Set swSketchSeg = vSketchSeg(i)
                        xValue(i) = swSketchSeg.x * 1000
                        yValue(i) = swSketchSeg.y * 1000
                        zValue(i) = swSketchSeg.z * 1000
                    Next i
                tFilename = swModel.GetPathName
                sFilename = Left(tFilename, Len(tFilename) - 7)
                Set fs = CreateObject("Scripting.FileSystemObject")
                Set f = fs.CreateTextFile(sFilename & ".txt", True)
                            f.writeline Format(xValue(i)) & "," & _
                            Format(yValue(i)) & "," & _
                            Format(zValue(i))
                   Next i
                f.Close
                MsgBox Left(swModel.GetTitle, Len(swModel.GetTitle) - 7) & ".txt file created under working directory"
                Exit Sub
                error:    MsgBox " please make sure that:" & vbCrLf & _
                            "1. Only one SolidWorks session is opened" & vbCrLf & _
                            "2. An Assembly or a part is the active document" & vbCrLf & _
                            "3. A Sketch feature is selected or active with nothing selected" & vbCrLf & _
                            "4. you are allowed to write to working directory.", vbInformation
                Exit Sub
                    Ivana Kolin
                    Option Explicit
                    swSketchLINE = 0
                    swSketchARC = 1
                    swSketchELLIPSE = 2
                    swSketchSPLINE = 3
                    swSketchTEXT = 4
                    swSketchPARABOLA = 5
                    End Enum
                    Dim swFeat1                         As SldWorks.Feature
                    Dim swFeat2                         As SldWorks.Feature
                    Dim swSketch                        As SldWorks.Sketch
                    Dim cSysData                        As SldWorks.CoordinateSystemFeatureData
                    Dim i                               As Long
                    Dim sFilename As String
                    Dim fs As Object
                    Dim f As Object
                        Exit Sub
                        Select Case swSelMgr.GetSelectedObjectCount2(-1)
                        Case 1
                            Set swFeat1 = swSelMgr.GetSelectedObject6(1, -1)
                            If swFeat1.GetTypeName2 = "CoordSys" Then
                                Set cSysData = swFeat1.GetSpecificFeature2
                            Else
                                MsgBox ("you must select coordinate system and the sketch from feature manager tree or at least be in a sketch")
                                Exit Sub
                                Exit Sub
                        Case 2
                            Set swFeat2 = swSelMgr.GetSelectedObject6(2, -1)
                                Set cSysData = swFeat1.GetDefinition
                            ElseIf swFeat2.GetTypeName2 = "CoordSys" Then
                                Set cSysData = swFeat2.GetDefinition
                            Else
                                Exit Sub
                            If swFeat1.GetTypeName2 = "ProfileFeature" Then
                                Set swSketch = swFeat1.GetSpecificFeature2
                            ElseIf swFeat2.GetTypeName2 = "ProfileFeature" Then
                                Set swSketch = swFeat2.GetSpecificFeature2
                            Else
                                Exit Sub
                        End Select
                    Dim mu As SldWorks.MathUtility
                    Set mu = swApp.GetMathUtility
                    Dim swSkXform As SldWorks.MathTransform
                    Set swSkXform = swSketch.ModelToSketchTransform
                    Set swSkXform = swSkXform.Inverse
                    Dim PointCoords(2) As Double
                    Dim vPt As Variant
                    Dim mt As SldWorks.MathTransform
                    Dim mp As SldWorks.MathPoint
                    Set mt = cSysData.Transform
                    Set mt = mt.Inverse
                        PointCoords(0) = swSketchSeg.X
                        PointCoords(1) = swSketchSeg.Y
                        PointCoords(2) = swSketchSeg.Z
                        vPt = PointCoords
                        Set mp = mu.CreatePoint(vPt)
                        Set mp = mp.MultiplyTransform(swSkXform)
                        Set mp = mp.MultiplyTransform(mt)
                        xValue(i) = mp.ArrayData(0) * 1000
                        yValue(i) = mp.ArrayData(1) * 1000
                        zValue(i) = mp.ArrayData(2) * 1000
                    Next i
                    sFilename = swModel.GetPathName
                    sFilename = Left(sFilename, Len(sFilename) - 7)
                        Format(zValue(i))
                    Next i
                    f.Close
                    Exit Sub
                    Exit Sub
