DPDanny Pearson28/03/2013
When working with a sheet metal part, if you have features below the Flat-Pattern feature, they are suppress in the formed state and unsuppressed when you are in the flattened state. I was wondering if there is a way to have features that will be unsuppressed in the formed state, and suppressed in the flattened state. Anyone know if this is possible?
So, if I do an extruded cut when it is formed, can I suppress that extruded cut when it's flattened? I need to do this without adding configurations; it has to be in the default configuration, not even in a flattened sub configuration.
In the attached part, I want Hole1 to suppress when I push the flatten button.
