0 Replies Latest reply on Mar 27, 2013 4:55 PM by Greg Johnson
    Adding prefix to slot dimension
    Greg Johnson
      I'm trying to add the prefix '2X' to a slot dimension using the API. I have been able to add the text successfully but when I do the slot dimensions no longer update if the slot changes size. To fix the problem I can cut the text out of the PropertyManager and paste it back in. Has anyone successfully added a prefix to a slot dimension using the API?
      Here is my code that updates the slot dimension;
      Const strInc As String = "X "
      Const strSlotCallout As String = "<hw-slot-width> X <hw-slot-length>"
      Dim strDimensionTextCalloutAboveDefinition As String = swDisplayDimension.GetText(swDimensionTextParts_e.swDimensionTextCalloutAboveDefinition)
      Dim strDimensionTextPrefixDefinition As String = swDisplayDimension.GetText(swDimensionTextParts_e.swDimensionTextPrefixDefinition)
      If strDimensionTextCalloutAboveDefinition.Contains(strSlotCallout) Or strDimensionTextPrefixDefinition.Contains(strSlotCallout) Then
           intNumValue = Val(strDimensionTextPrefixDefinition)
           If intNumValue = 0 Then intNumValue = 1
           If strDimensionTextPrefixDefinition.Contains(strInc) Then strDimensionTextPrefixDefinition = strDimensionTextPrefixDefinition.Replace(Format(intNumValue) & strInc, "")
           intNumValue = intNumValue + x
           If strDimensionTextPrefixDefinition.Contains(strSlotCallout) Then
                strDimensionTextPrefixDefinition = strDimensionTextPrefixDefinition.Replace(strSlotCallout, "")
           If intNumValue > 1 Then
                swDisplayDimension.SetText(swDimensionTextParts_e.swDimensionTextPrefixDefinition, Format(intNumValue) & strInc & strDimensionTextPrefixDefinition & strSlotCallout)
           Else
                swDisplayDimension.SetText(swDimensionTextParts_e.swDimensionTextPrefixDefinition, strDimensionTextPrefixDefinition & strSlotCallout)
