Hi
I am working on an electronic devise, need create wire between connector and board pad, I try to use routing to create this wire, but didn't work, I don't know why, anybody can tell me how? Detail see below.
Thank you very much
Ping
Hi
Thank you very much
Ping
I tried create cp on both parts, but I don't know how to route them, please tell me more detail. Thanks
If you have cpoints defined in both parts, all you should have to do then, at a minimum, is insert them both into the assembly, make sure your routing plug-in is active, right click the first part and select "start route", at this point, i cancel the autoroute command, right click the other component and select "add to route". Then you'll have wire stubs protruding from both components, Then you can use the autoroute command, or simply draw splines between wire stubs to create the route, then you're golden.
You need to create connection points on your PCB part. Use a sketch to define the location & orientation of your connection points & then route between the appropriate points.
