6 Replies Latest reply on Mar 29, 2013 10:35 AM by Christian Chu
    remove items from combo box
    Christian Chu
      This is a simple code but I coudlnt' figure out how to removeitem from the combo box. Any help, please
      I want to add from letter "A" to "Y" to the cboRev.  except "I" "O" "Q" "S" and "X"
      Thx
           istart = 65 ' Start with letter "A"
          iEnd = 89   ' End with letter "Y"
          iSkip(0) = 73 'Letter "I"
          iSkip(1) = 79 'Letter "O"
          iSkip(2) = 81 'Letter "Q"
          iSkip(3) = 83 'Letter "S"
          iSkip(4) = 88 'Letter "X"
                    iListIndex = 0
                    For i = istart To iEnd
                      cboRev.AddItem Chr(i) 'Add letter "A" to "X" to the cboRev
                      iListIndex = iListIndex + 1
                      For j = 0 To 4
                          If i = iSkip(j) Then cboRev.RemoveItem (iListIndex - 1)
                      Next
                  Next
        • Re: remove items from combo box
          Manish Kumar
          Try this
          Dim istart As Integer
          Dim iEnd As Integer
          Dim collItemToSkip As New Collection
          Call collItemToSkip.Add(73, "k-" & 73) 'Letter "I"
          Call collItemToSkip.Add(79, "k-" & 79) 'Letter "O"
          Call collItemToSkip.Add(81, "k-" & 81) 'Letter "Q"
          Call collItemToSkip.Add(83, "k-" & 83) 'Letter "S"
          Call collItemToSkip.Add(88, "k-" & 88) 'Letter "X"
          On Error Resume Next
          iListIndex = 0
              Dim item As Integer
              item = collItemToSkip.item("k-" & i)
              If item = 0 Then
          Next
            Simon Turner
            You could just avoid adding those items in the first place.
            The problem with your code by the way, is that you need to subtract 1 from iListIndex after removing the item from the list (otherwise it is too large).
              Jacob Cordingley
              Sub fillcombo(ByVal excludelist As List(Of Char))
                      For ii As Integer = 65 To 90
                          If Not (excludelist.Contains(Convert.ToChar(ii))) Then
                              ComboBox1.Items.Add(Convert.ToChar(ii))
                      Next
                Dim xChar As New List(Of Char)
                xChar.Add("I")
                xChar.Add("O")
                xChar.Add("Q")
                xChar.Add("S")
                xChar.Add("X")
                xChar.Add("Z")
                fillcombo(xChar)
