Just tried for fun in Sheet Metal and got an interesting question -
Attached Zipped file includes 2 part files- MM_#091 and MM_#098.
#098 is the mirrored part from #091.
#091 can generate flatten, no problem.
But I cannot flat #098.
Is there any trick in the model?
Best Regards,
Wayne
Good morning Fred,
Thanks -
There are different ways to model different components, did you try it with Wayne's part? You can do it that way, however for me it is much quicker just adding the Sheet Metal Bend Feature, (you only need to select one face and your done, no need to check this face then that face etc...), and if there is an issue it stems back to the original part anyhow..
Later,
John
