Hai all, please help in solving the problem that occurred when i transfer fld file to simulation for static stress analysis, it keep showing "no load....." even i have added up all the goal in pressure (global, surface, volume -min, max, ave)
thanks
wernyu
what are the exact steps you used?
did you remember this first step:
Click Flow Simulation > Tools > Export Results to Simulation. Flow Simulation will traverse over all model surfaces and make the fluid parameters available for SolidWorks Simulation.
have you checked your method using a simple part? (start with a block in an external flow)
the other thing to check is that you have the right faces available in your model. for example if your model has switched to beams for simulation, i don't think the flow results will transfer over. check with solids first.
