2 Replies Latest reply on Mar 23, 2013 2:33 AM by Vajith P N
    Created two parts in the same part file - How can you separate into Two part files
    Doug Kohring
      I wasn't really thinking when I modeled the first and second stage shots of a molded part into a single file. So the hard plastic first stage and the soft plastic second stage are all in the same part file. Now the hard plastic first stage is fine but we want to do some experimental soft plastic forms. It would be significantly better to have these as individual parts rather than more features inb the same part.
      In Unigraphics they had this slick command where you could select a solid and do a save as and all the features that created that solid would be saved into the new file. Does Solid Works have any similar command or if not what is the best way to separate these two files?
      Thanks in advance for the help!
      Doug
