0 Replies Latest reply on Mar 22, 2013 10:09 AM by Kevin Stickels
    ePDM 2012 and AutoCAD *.dwg files
    Kevin Stickels
      Has anyone experienced this issue with AutoCAD drawings and ePDM?
      Designer checks out a *.dwg file from the vault.
      Designer modifies and saves the *.dwg file
      Designer saves a copy of the drawing as a *.pdf
      Designer checks in *.dwg & *.pdf drawing back into the vault
      The vault "appears" to lose the *.dwg file and reverts to an older version (but appears to maintain the correct revision/ title blocks).. It saves a backup file with everything correct.  I have only started to investigate this issue this morning so I have not delved deeply yet. Just sending out feelers to see if any other forum members have seen this before...
