I am curious if I am experiencing an anomaly, but I am currently working on a small assembly which was working just fine. I then started grouping items in folders in the design tree to make it a little more organized, but the more folders I created, the slower the assembly started to respond to the point where I would select an item, and it would take 5 or 6 minutes to respond. Is this normal behavior? Should I not create these folders?
TIA,
Jason Lackey
Jason,
I don't know. Try deleting all of your folders and see if it speeds back up again. If it doesn't, don't save it before closing it out. If it does, we will all have learned a valuable lesson.
Jerry S.
