AHAdam Hughes20/03/2013
So out of curiosity, I am wondering why OpenGL is not enabled when my GPU supports OpenGL 4.2. I have the latest drivers and OpenGL tests just fine on FurMark and other testing applications. OpenGl and OpenCl and DirectX11 are enabled . . . but SolidWorks does not recognize the GPU as OpenGL compatible, why is this. I know the easy answer to this question is " its not on the support list of SolidWorks website  . . . but why not, when it suppots OpenGL?
Intel 3970k 6 core 4.2GHz
64GB 2400 Ram
(x2 crossfire) AMD 7970 GPU OpenGL 4.2 OpenCL 1.2 DirectX11.1
(and yes rebuild/rendering/simulation times are ridiculously fast)
see mfg info below (directly copy and pasted)
  • 1GHz Engine Clock (up to 1.05GHz with boost)
  • 3GB GDDR5 Memory
  • 1500MHz Memory Clock (6.0 Gbps GDDR5)
  • 288GB/s memory bandwidth
  • DirectX® 11.1-capable graphics
    • 9th generation programmable hardware tessellation units
    • Shader Model 5.0
    • DirectCompute 11
    • Accelerated multi-threading
    • HDR texture compression
    • Order-independent transparency
  • OpenGL 4.2 support
    • Partially Resident Textures (PRT)
      • Ultra-high resolution texture streaming technology
  • Image quality enhancement technology
    • Up to 24x multi-sample and super-sample anti-aliasing modes
    • Adaptive anti-aliasing
    • Morphological Anti-Aliasing (MLAA) 2.0
    • DirectX® 9/10/11 Super Sample Anti-Aliasing (SSAA)
      • Automatic LOD adjustment (Requires AMD Catalyst™ 12.4 or higher)
    • 16x angle independent anisotropic texture filtering
    • 128-bit floating point HDR rendering
  • AMD Eyefinity multi-display technology4
    • Up to 6 displays supported with DisplayPort 1.2 Multi-Stream Transport
    • Independent resolutions, refresh rates, color controls, and video overlays
    • Display grouping
      • Combine multiple displays to behave like a single large display
  • AMD App Acceleration3
    • OpenCL 1.2 Support
    • Microsoft C++ AMP
    • DirectCompute 11
    • Double Precision Floating Point
    • AMD HD Media Accelerator
