15 Replies Latest reply on Mar 20, 2013 2:04 PM by JD Sareault
    Select all the edges on a face
    JD Sareault
      Is there an easy way to select all or most of the edges on a face at once? I'm trying to apply a draft to a part with hundreds of holes of a specific shape that needs to be maintained, so I'd like to preselect the edges and then apply a parting line draft. Is there an easy way to do this?
        • Re: Select all the edges on a face
          Bjorn Hulman
          right click on the edge and use select loop. You can change the loop  by clicking the yellow arrow.
            Lenny Bucholz
            you can also use the selection filter set to edges only and rubberband around the part and it will pick the edges only.
            Message was edited by: Lenny Bucholz
              Jacob Corder
              When all else fails, create a macro. Get the selected face, and then you will have to loop in the code to select all edges. Quite simple actually. If interested I could help you with the code
                  JD Sareault
                  That might be my best bet. Where do I get started coding this? I've done a little programming before but I've never used macros in Solidworks
                      Jacob Corder
                      Dim swApp As Object
                      Dim ModDoc As ModelDoc2
                      Dim boolstatus As Boolean
                      Set ModDoc = swApp.ActiveDoc
                      Dim SelMgr As SelectionMgr
                      Dim EdgeCount As Integer
                      Dim Edges() As Edge
                      Dim SelFace  As Face2
                      Dim SelData As SelectData
                      Dim SelectedCount As Integer
                      If ModDoc Is Nothing Then
                      Else
                           Set SelMgr = ModDoc.SelectionManager
                           If SelMgr.GetSelectedObjectCount2(-1) = 1 Then
                                Select Case SelMgr.GetSelectedObjectType3(1, -1)
                                          Case swSelectType_e.swSelFACES
                                               Set SelFace = SelMgr.GetSelectedObject6(1, -1)
                                               If SelFace Is Nothing Then
                                               Else
                                                    EdgeCount = SelFace.GetEdgeCount
                                                    Edges = SelFace.GetEdges
                                                    Set SelData = SelMgr.CreateSelectData
                                     ''If you only want edges and not the original face then uncomment this out
                                                    ModDoc.ClearSelection2 (True) ' This Clears the selected Face
                                                    SelectedCount = SelMgr.AddSelectionListObjects(Edges, SelData)
                                                    swApp.SendMsgToUser2 "There Were " & SelectedCount & " Edges Selected", _
                                                swMessageBoxIcon_e.swMbInformation, swMessageBoxBtn_e.swMbOk
                                End Select
                        Jacob Corder
                        Also we can filter the types of edges using curve objects. just create a new macro, and paste this in. if you dont want the face still selected then leave it as is, if you want the face still selected comment out  or use a ' in front of the ModDoc.ClearSelection2.
                        If you need this to go into a feature type form we can do that to. i just need to know that form. i think you said draft. or select the face, run this macro, then hit the feature.
                        have you used macro buttons?
                        if not right click the command mananger, select customize, select the commands tab, select macro under categories, then the icon to the farthest right is a macro button that you can drag into any command mananger tab and link it to a macro.
