Hello.
I need to determine somehow if there any intersections of solids (SWEEPS) in a model.
For example: if model consists of two sweeps - if there any possibility to check it for their intersection? Some kind of add-in or macro?
In attached files i've shown up what i need
Welcome to SolidWorks forums 1 1.
There are two thing you can try right now:
1. In part mode, go to Insert > Feature > Combine and use the option common. Then select all the bodies and see if there is anything left out which will be typically the intersection area/volume.
2. You can also convert you part file with multibody quickly to an assembly (No mates required). Now you can use interference detection tool in the assembly.
In either case when you make multibody part, make sure Merge result option is not selected in the features (like when you do sweep, extrude, revolve)
You might also find this post helpful for your future reference.
