2 Replies Latest reply on Mar 18, 2013 11:42 AM by Chris Tellers
    Color Changing Macro
    Chris Tellers
      Good Morning
      I am running the code below to cycle through a user selected faces or features to change them to the selected color (I have a userform they select the color from)
      Everything works great except when you select more that 2 of any type (face or feature) it does the first two selection fine then it will not set the vProps Variable.  Not sure what I am missing.
      Code -------------------------------------------------------------------------
      Sub Color_Code()
      Dim swFace As SldWorks.Face2
      Dim swFeat As SldWorks.Feature
      Dim i As Integer
      Dim vProps As Variant
      Dim Part As Object
      Dim boolstatus As Boolean
      Set swModel = swApp.ActiveDoc
      For i = 1 To swSelMgr.GetSelectedObjectCount2(-1)
          If swSelMgr.GetSelectedObjectType3(i, -1) = swSelBODYFEATURES Then
              Set swFeat = swSelMgr.GetSelectedObject6(i, -1)
              vProps = swFeat.GetMaterialPropertyValues2(i, Empty)
              vProps(0) = VProp0
              vProps(1) = VProp1
              vProps(2) = VProp2
              vProps(3) = 1
              vProps(4) = 1
              vProps(5) = 0.8
              vProps(6) = 0.3125
              vProps(7) = 0
              vProps(8) = 0
              swFeat.SetMaterialPropertyValues2 vProps, swAllConfiguration, Empty
          ElseIf swSelMgr.GetSelectedObjectType3(i, -1) = swSelFACES Then
              Set swFace = swSelMgr.GetSelectedObject6(i, -1)
              vProps = swFace.GetMaterialPropertyValues2(i, Empty)
              vProps(0) = VProp0
              vProps(1) = VProp1
              vProps(2) = VProp2
              vProps(3) = 1
              vProps(4) = 1
              vProps(5) = 0.8
              vProps(6) = 0.3125
              vProps(7) = 0
              vProps(8) = 0
              swFace.SetMaterialPropertyValues2 vProps, 1, Empty
          Else
              MsgBox "Please select a Feature or Face"
      Next i
      swModel.ClearSelection2 True
      'Closes User Form
      If PinDialogValue = 1 Then
          'Do Nothing
      Else
          Unload ColorManager
      'Redraw to see new color
      swModel.GraphicsRedraw2
      Any help would be greatly appreciated.
      Chris
