Hi everybody
I work at a company in a transition between two programs. At the moment we are generating every .PDF and .DWG manually. To make this easier i started making a macro to make the process faster and automated. Problem is that i am stuck.
Dim swApp As Object
Dim Part As Object
Dim boolstatus As Boolean
Set swApp = _
Application.SldWorks
Set Part = swApp.ActiveDoc
Part.ClearSelection2 True
longstatus = Part.SaveAs3("O:\Solidworks Dokument Arkiv\Filer 2013\PDF\1099815734.PDF", 0, 0)
Part.ViewZoomtofit2
Part.ViewZoomtofit2
Part.ViewZoomtofit2
This is as far i can get on my own. This macro generates a pdf from my drawing. Trouble is that it allways names the pdf the same as the part i recorded the macro from.
In my head the above line is the only thing that needs changing. I need it to get the filename from the part on the sheet instead of the recorded number.
I really hope there is someone out there who can offer me a hand.
Regards
Rasmus Hansen
Carsoe A/S
Mechanical Engineer
Try this macro. You can set a button or keyboard shortcut to run the macro. Macro will save PDF and DWG of the active drawing in the same location as drawing.
Edit: Macro updated!!
