15 Replies Latest reply on Mar 19, 2013 7:07 PM by Radoslaw Koneczny
    Need some help simulating NonLinear displacement graph
    David B
      Hello everyone,
      I want to find a non-linear displacement graph of a Silicone membrane when applying different uniform pressure on it.
      This is what I do:
      I have a round membrane with 20 microns radius and 1 micron thickness made of silicone that is clamped around perimeter as you can see in the picture below.
      I add uniform pressure that is normal to the surface of the membrane.
      Then I run the analysis and get the displacement.
      The problem is that if I double the pressure the displacement result is doubled as well and I know that it should not be this way. What am I doing wrong? Maby I should use another analysis method or change something in the model? Any help would be apprecierated
      Best regards,
      David
      P.S. I am using the Static simulation tool.
      As for material properties I used:
      Elastic Modulus in X1.48e+011N/m^2
      Poisson's Ration in XY0.1773N/A
      Mass Density2329kg/m^3
