I am using SolidWorks 2012 and when routing tubing with custom fitting that I created with the wizard, there are no route parts created when the routing is exited. When using the example fittings that come with SolidWorks the route parts are created. All I have when I exit the routing when using the custom fittings is the 3d sketch with no solid sweep for the tubing. I have tried comparing the part I made with the example one and cannot find any differences.
Thanks for the help.
Cody,
Welcome to the forum.
There's so many things that could be wrong that it makes it difficult to help you. There for if at all possible it would be easiest if you post the part you made.
A couple of things you can do is check if you're used the correct terminology, with the correct spelling, and if the dimensions that you use for the custom fitting are identical (to the last decimal) with those from the tubing.
