Hi
I might be floating an enhancement request here, but does anyone know of a way to "isolate"** a component along with all components that are directly mated to it, for example (and in very simple terms) a bracket with all fasteners that hold it to another item, without showing the other item and without having to individually select each item for isolation.
**I use the term isolate in inverted commas as there may be a way to achieve this without using the actual isolate command.
Davey
Select the component
goto the Select flyout menu, expand it and click on 'Select Mated to'
Hold down CTRL and select the initial component again ('select mated to' will deselect it)
RMB and select 'Isolate'
I have 'Select mated To...' hotkeyed.
